SRC3000XLI is blinking between mode battery and mode network
Send InviteCancel
Posted: 2024-05-2007:56 AM
Upload the active faults / errors logs from the system and insure it’s visible in the APC Forum. I can’t understand what the problem is based on what you’ve stated. So the logs will help narrow down the problem(s).
If you want to upload a photo / video of the LED even better! 👍
