SNMP or SSH to shutdown
  • SNMP or SSH to shutdown
Posted: ‎2021-06-30 07:19 AM . Last Modified: ‎2024-03-07 11:14 PM
2526
I'm working on an huge processing project and I am writing a full shutdown script for the entire operation in bash. I was wondering if anyone knew any way to encorporate a manual shutdown of the UPS unit using either SNMP or SSH?
Janeway
If your UPS' have APC's network management card installed on them, then you can use SNMP. Check out this item from the [PowerNet MIB|http://support.ipmonitor.com/mibs/POWERNET-MIB/oids.aspx]:
upsAdvControlUpsOff: 1.3.6.1.4.1.318.1.1.1.6.2.1
Values:
1) noTurnUpsOff
2) turnUpsOff
3) turnUpsOffGracefully
4) turnUpsSyncGroupOff
5) turnUpsSyncGroupOffAfterDelay
6) turnUpsSyncGroupOffGracefully
As an example, if your NMC has SNMP v1 enabled and allows the public community write-access to the device, then you could to this with the [Net-SNMP|http://net-snmp.sourceforge.net/] set of tools:
snmpset -c public -v 1 IP_of_ups 1.3.6.1.4.1.318.1.1.1.6.2.1.0 i 2
I hope that helps.
Janeway
Values:
1) noTurnUpsOff
2) turnUpsOff
I hope that helps.
