SNMP DA807 network card default IP address
  • SNMP DA807 network card default IP address
Posted: ‎2021-09-02 12:45 PM
1
7867
Good day everyone,
On a customer site i installed today an SNMP DA807 network card (on Easy UPS 3S 20KVa model with internal batteries).
I have a hard time trying to access the web interface and configure the network card, reading the manual i cant find its default IP address and it does not seems to automatically obtain an IP address from the DHCP server.
The quick installation manual states the following:
3.2 Web Interface
To check whether the SNMP Card (DA807) is operational after installation and
configuration, proceed as follows.
◗ Run a browser
◗ Enter in the address bar:
Get the IP address from Easy UPS 3PH SNMP Manager.
◗ The home page is displayed Connect
Where can i find this Easy UPS 3PH SNMP Manager?
Is it a software that is publicly available and i can download? I am not able to reach it in downloads section or by searching the web, in addition i don't have any clue for the IP address at all...
Many thanks in advance for your support, all the best.
BR,
Manos
Shaun
Commander Shaun Commander
Commander
Posted: ‎2021-09-16 03:03 AM
I don't believe this card ships with dhcp by default.  The goal is that the "snmp manager" tool should be able to discover it, but in the factory default state it ships with the IP set to 192.168.5.105 (/24), and should be available via https.  I do often find it's much easier to set a laptop to the same network, hook straight up to the ethernet port and use the web UI to set it for the network as appropriate.  Less convenient, but less to go wrong.
