Posted: 2021-06-25 11:08 PM . Last Modified: 2024-03-19 03:20 AM
For some reason SMTP configuration is not working for me. I am using Microsoft Office 365 and test mail keeps failing
Can any one please help
Posted: 2021-06-25 11:09 PM . Last Modified: 2024-03-19 03:20 AM
After a year of fighting this I made a Gmail account and tested it.. found that the SMTP server settings hold absolutely no ****ing bearing on what the recipients pull and is actually a useless spot.
I went to the recipient which showed the same data as the server, cleared it and redid it. Tested worked...
What a joke..
Have you reviewed Schneider Electric FAQ FA164769? The FAQ discusses configuring email with NMCs.
When I have tested I have used
smtp.office365.com
Port: 587
Encryption: SSL/TLS = Always
Thanks for your reply.
I also used the same configuration, but still getting the same error.
We are using Mimecast as Email Security Gateway and our MX record is pointed to "eu-smtp-inbound-1.mimecast.com". Hence I have tried below configuration as well
SMTP : eu-smtp-inbound-1.mimecast.com
Port : 25
SSL/TLS : Always
I am still getting the error : 530 5.7.57 SMTP; Client was not authenticated to send anonymous mail during MAIL FROM [DB6PR06CA0036.eurprd06.prod.outlook.com]
I'm having the same issue and we also use Mimecast.
Except im getting a 535 5.7.3 Authentication Unsuccessful and the credentials are 100% valid...
Direct Connect worked up until after 12/20/2018 so something changed with Office 365. It would PROBABLY be advantageous of the VENDOR to figure out WHY so their CUSTOMERS can fix the issue....
Jasim, did you ever get this working?
On 3/28/2019 3:51 AM, Jasim said:For some reason SMTP configuration is not working for me. I am using Microsoft Office 365 and test mail keeps failing
What a joke..
