SMTP - 535 authentication failed
  • SMTP - 535 authentication failed
CortexIT
CortexIT
Cadet
Posted: ‎2024-08-22 03:04 AM
1476
Hello everybody,
I'm trying to use SMTP on an ups SRT3000XLI without success.
When I test it, I receive the following message:
Last Test Result
Test E-mail sent successfully.
Last Server Response
535 Authentication failed: The provided authorization grant is invalid, expired, or revoked
The test result is successfully but the server response failed.
Mail has not be sent.
When I try to send a email from a Telnet cli with same parameter, all works fine. It's why I think there is a problem with the NMC3 and SMTP.
Thanks a lot for your help
Best regards
Xavier
Replies 5
Kirk
Posted: ‎2024-08-22 06:44 AM
Given you have provided absolutely no relevant SMTP (UPS Settings) information and the email provider you’re trying to reach or how email is handled in your environment.
I’ll keep this simple . . .
Using the NMC Test, send an email to gmail, Hotmail, etc what happens?!?
CortexIT
CortexIT
Cadet
Posted: ‎2024-08-22 11:40 PM
NMC test answer still the same:
I try to use the SMTP service from sendgrid.net
this one works well when I try with another "SMTP client" then the NMC.
Do you know where I can find logs and if I can test on the NMC directly in CLI?
Other idea still welcome.
Thank you and best regards
Xavier
guillerosemberg_apc
Crewman guillerosemberg_apc
Crewman
Posted: ‎2025-04-22 10:22 AM
2
946
Exactly the same issue here, starting to think NMC3 password field does not suppor the lenght of the api key.
AldAjacob
AldAjacob
Cadet
Posted: ‎2025-10-30 11:57 AM
In response to guillerosemberg_apc
This is correct. Just found this out today. I think it's 3 or 4 characters short and sadly can't be fudged through inspect. I ended up using smtp2go instead of sendgrid.
dd7
dd7
Cadet
Posted: ‎2025-11-18 04:02 AM
That is correct..  the password field has a limit of 64 characters and the sendgrid api key is longer.
