Restrict access to the web resources on ap9631
  • Restrict access to the web resources on ap9631
Posted: ‎2021-06-30 01:34 AM . Last Modified: ‎2024-03-11 12:59 AM
1222
Hi, we have an AP9631 NMC. It was scanned by our network security software and found to have vulnerabilities with web files. Is there any way to restrict access to scripts/mailtoform.html? If not, can it be disabled?
Thanks in advance!
Thanks a lot voidstar! I areally appreciate your help.
Replies 5
Janeway
Usually such scanners indicated potential vulnerabilities based on evidence from the scan.
The NMC doesn't have such a page, but I notice that the web server returns a "protected object" page for any URL under scripts/. That might have tripped up the scan which is looking for the existence of a specific script it knows is vulnerable. In this case, the script doesn't actually exist but the scan thinks it does.
I'm not sure how much I can say about the next release of the NMC firmware, but you'll have plenty of capability to limit access to the device.
Thanks voidstar!
What about disabling the web access altogether? So, nobody will be able to access the web interface at all.
Again, thanks.
First question is answered. Not sure if I am doing this right. See my last post. Wondering if I can disable web access altogether.
Thanks!
Message was edited by: jschoen
Janeway
Thanks voidstar!
On the web interface under networking, there's a section to disable the web server. You can also change the port so that the scan may not find it. If you need to re-enable the web server at a later time, you can use the "web" command through telnet, ssh, or the card's rs232 configuration port. You can also enable/disable or configure the web interface by FTPing in an appropriate .ini file, which is nice for configuring multiple devices.
That said, I hope you can explain to the right people that the scan didn't find an actual vulnerability.
Best of luck!
