Posted: 2021-06-30 03:03 AM . Last Modified: 2024-03-08 05:00 AM
I try to configure like this in the field "Full path of the command file": ....see attached picture...
Powershell.exe -WindowStyle Hidden -command "C:\Scripts\APCsendEmail.ps1" or only this C:\Scripts\APCsendEmail.ps1
Both do not work. Have anybody an idea for this isuue?
Thanks for help
Frank
Posted: 2021-06-30 03:03 AM . Last Modified: 2024-03-08 04:59 AM
This may be due to restrictions on running unsigned powershell scripts.
To view the current policy:
PS C:\ Get-ExecutionPolicy
To change the setting:
PS C:\ Set-ExecutionPolicy -ExecutionPolicy Unrestricted etc (to view options run help Set-ExecutionPolicy)
Then create a .cmd file to run the script:
Powershell.exe -WindowStyle Hidden c:\
Message was edited by: pcnsqa
You probably need to create a .bat file to launch Powershell with your script as an argument. See example 2 here:
http://nam-en.apc.com/app/answers/detail/a_id/1784
Then give PCNS the path to your .bat file.
hi frank. i am not sure if that will work.
check out the following knowledgebase articles.
http://nam-en.apc.com/app/answers/detail/a_id/2441/
http://nam-en.apc.com/app/answers/detail/a_id/1784 (this is for XP, 2000, etc) but I think still applies.
hope that helps!
THX
But it will not help....;-(((
FRank
I tried also a CMD and BAT file for execution.
Frank
Here is the ps code: ...
$Emailserver = "exchange.xxxxxxx"
$mail = New-Object System.Net.Mail.MailMessage
$mail.From = APC-PowerChute@xxxxxx
$mail.To.Add("it-hotline@xxxx")
$mail.Subject = "Check the power on: $env:computername"
$mail.Body = "ATTENTION!!!!!!!!!!!!!! Check Power on server $env:computername!!!!"
$smtp = New-Object System.Net.Mail.SmtpClient($Emailserver)
$smtp.Send($mail);
Maybe I need a module?
Frank
here the solution:
powershell.exe -ExecutionPolicy Unrestricted -NoProfile -NonInteractive -file c:\scripts\APCSendEmail.ps1
Best
Frank
