Powerchute network shutdown, the commad line
  • Powerchute network shutdown, the commad line
Posted: ‎2021-06-26 12:57 AM . Last Modified: ‎2024-03-19 02:40 AM
964
Hi *
I have a SRT5KXLI and Powerchute Network Shutdown : v. 4.3.0.
1) Issue with the command line:
It works with a *.bat or *.exe, but not with parameters in the line.
I tried also to add @start in the line, it does not work at all.
2) FYI:  Solution for another issue : Windows isolates services in Session 0
I found a way around the issue : "Win 10 isolates services in Session 0 ... PowerChute is run in Session 0 so if a command file launches a .exe that .exe will be launched in Session 0 and not visible to the logged in users. "
But I did cost me 2 days of work, was it documented elsewhere?
My Method :
a - I run a command line  *.bat file to create a window event
eventcreate /l application /t information /so "UpsPowerchute" /id 100 /d "UPS On Battery"
and
b - I Create a Windows Task based on this event
Windows task scheduler will be triggered by this newly created event, and start an action.
You can import a predefined XML task file. Manual method : (GUI may varie a bit depending on Windows flavor (Win 7 / 10 / 10 pro / etc … )
  • Open “Task Scheduler” (taskschd.msc)
  • Menu: Action > Create basic task :
  • Name: UPS_On_Battery
  • Trigger : When a specified event is logged
    • Log: Application
    • Source : UpsPowerchute
    • Event ID : 100
  • Action : Start a Program / script:
    • 1 2 C:\blabla\Tools\blabla.exe parameters
    • To be able to create a Windows Event via DOS command eventcreate, you shall first create a RegEdit entry for the source UpsPowerchute you create :
      Regedit
      1 2 3 4 5 6 7 The key associated with an event source "UpsPowerchute" is
      Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\EventLog\Application\UpsPowerchute
      EventMessageFile
      Value= %SystemRoot%\System32\EventCreate.exe
      CustomSource
      Value= 1
  • General Questions & Suggestions
  • it
  • windows10
Tested PCNS 4.3 with a .bat to shutdown a remote Windows server and it works fine.  shutdown /s /f /m \\192.168.10.12 /c "PowerChute has initiated a system shutdown" /t 10
NOTE: you have to change the PowerChute user from local system account to an account that can access the remote server.
