Need a UPS? Learn the difference between Watts versus Volt Amps (VA)
Send InviteCancel
Posted: 2021-06-2812:25 PM. Last Modified: 2024-03-1504:08 AM
If you are in the market for a UPS and you want to learn how to size your UPS correctly, listen to this podcast or read this White Paper to learn about watts and volt amps commonly referred to as VA.
White Paper #15 helps explain the differences between Watts and VA and explains how the terms are correctly and incorrectly used in specifying power protection equipment.
Length: 9 minutes
Language: English
Format(s): RSS or MP3 download
