NMC2 - Config.ini does not contain all of the settings
  • NMC2 - Config.ini does not contain all of the settings
Posted: ‎2021-07-07 11:44 PM . Last Modified: ‎2024-02-29 11:46 PM
898
I have downloaded the config.ini file from several of my NMCs trying to put together a comprehensive list of settings to push out to several dozen UPSs, but none of them seem to be complete, they tend to end mid-setting in many cases. I've made changes and when the new config.ini is created, it still ends in the same place.
Example:
; Environment: A fault no longer exists for external Environmental Monitor input contact 2 ({name} at {location}).
E0304=ES,E[-:-:-:],T[:::::],P[:::]
; Environ
That's it. it ends there.
Any ideas? I need a full list of all of the settings to make sure my notifications are are setup comprehensively. How many settings are there? Is there a full list somewhere? Will I be able to upload everything or is there a limit to the file size (or length) you can upload?
Mostly (possibly all) AP9631 NMC are being used.
I have been using ftp to download the config.ini file directly. That's the file that was ending.
In the web interface, I couldn't find the "generate logs" on most of my devices (Old Firmware). So ... updating a whole bunch of Management Card firmwares I guess.
But ... Yes that was very helpful, downloading the logs that way did give me the whole file it seems.
Thanks!
B-DoubleE_apc
Commander B-DoubleE_apc
Commander
Hi Steve,
What model NMC do you have? AP9630/31/35, embedded NMC in a PDU, etc?
What method are you using to download the config.ini file? Have you tried the "generate logs" method through the web interface? Under About --> Support, then click "generate logs" and "download".
Thanks!
