NMC Firmware Update Utility - languages?
  • NMC Firmware Update Utility - languages?
Posted: ‎2021-06-28 11:34 AM . Last Modified: ‎2024-03-15 04:57 AM
1159
Hello!
My company has a lot of devices with AP9630 card and it is tiresome to update them all manually. I figured out how to update several devices via NMC utility. To do that you need to edit the devices.txt file. However, there is a Language= parameter in this file which I do not know how to fill. Whatever I write there, the utility produces an error "wrong index" during the update. The thing is that English is not the native language in my country, so the change of language in the update is relevant.
I have already tried to write the following parameters:
- abbreviated name of the language (Ru Es It for example)
- full name of the language (Spanish, Japan, etc.)
- language pack file name in bin folder
- full path to the language pack file
- numbers (just in case)
None of this has helped.
Please write in detail how to fill in the "Language=" option in the devices.txt file.
Thanks.
P.S. utility version - 1.0.1.0, the utility file was called apc_hw05_aos688_sumx688_bootmon109.
Posted: ‎2021-06-28 11:34 AM . Last Modified: ‎2024-03-15 04:56 AM
Hi Artem,
You should be able to just leave the language field blank unless you want to upload a language pack to the NMC, if you want to upload a language pack then use one of the following:
Language=frFrruRuzhCnjaJakoKo
Language=frFrdeDeruRuitItesEs
Language=frFrdeDeitItesEsptBr
Language=esEszhCnjaJaptBrkoKo
-Gavan
Hi Artem,
-Gavan
Thanks a lot!
Tried this and it works!
