Posted: 2021-06-28 06:23 AM . Last Modified: 2024-03-18 02:23 AM
I need to get the power from all outlets of an AP8653. I would use snmp, so I need to know the MIB OID. I find rPDUOutletStatusLoad that returns the load in Amps, but I need the power in watts. Do you know what OID I should use?
Thanks for your reply. It's the OID that I need!
you should be under the rpdu2 tree to begin.
try these OIDs - you should get a reply for each outlet
.iso.org.dod.internet.private.enterprises.apc.products.hardware.rPDU2.rPDU2Outlet.rPDU2OutletMetered
under here you'll see: rPDU2OutletMeteredStatusTable, then rPDU2OutletMeteredStatusEntry. under there is the breakdown. a reply should come back for each outlet. i assume you need .1.3.6.1.4.1.318.1.1.26.9.4.3.1.7 which is
.iso.org.dod.internet.private.enterprises.apc.products.hardware.rPDU2.rPDU2Outlet.rPDU2OutletMetered.rPDU2OutletMeteredStatusTable.rPDU2OutletMeteredStatusEntry.rPDU2OutletMeteredStatusPower
you're welcome 🙂
