Posted: 2021-06-28 06:33 AM . Last Modified: 2024-03-18 01:25 AM
I am trying to set up one of these devices in a lab setting so that we can have the people we are working with remotely reboot their devices via the network controller. Is there a way to create multiple user accounts instead of giving full admin access to all users? I want to remove all possibility of users accidentally rebooting other user's devices. I am not seeing a way to do this, unless there is a firmware upgrade or something akin to that.
Thank you.
i dont believe so on those older units. on our newer Rack PDUs, we support administrators, device level users, and read only users. Then, we also have an outlet user level type where an administrator can designate which outlets each outlet user can control or configure. that sounds like what you'd need. we also support RADIUS on newer devices and all of these permission levels can be utilized with RADIUS as well.
Drat, I feared as much. Thank you for the reply. I'll look into it and talk to the guys in charge.
no problem.
