Posted: 2021-06-28 12:12 AM . Last Modified: 2024-03-18 11:35 PM
I have an AP7722 Automatic Transfer Switch with AP9617 Network Management Card. How can I get or check latest firmware?
I try to install AOS_3.5.7 and ATS_3.5.6 without success.
David
Factory Data
Model # - AP7722
Serial # -
Hardware Rev -
Manufacture Date - DD/MM/YYYY
Firmware Rev - 1.9
Firmware Date - 03-08-04 14:05
About System
Model Number : AP9617
Serial Number : JA0310004086
Manufacture Date : 03/03/2003
Hardware Revision : A10
MAC Address : 00 C0 B7 68 96 97
Flash Type : AMD A29DL322DB
Module Information
Description : Automatic Transfer Switch APP
Name : ats Type : StatApp
Version : 261 Sector : 12
Date : 11/18/2004 Time : 17:21:42
CRC16 : C1D8
Press
Description : Network Management Card AOS
Name : aos Type : APC OS
Version : 264 Sector : 51
Date : 11/12/2004 Time : 19:40:33
CRC16 : C476
Dear Matt,
Thank you for your response, ref to our discussion please guide me for up gradation of AP7722 where its hardware version showing 1.12 but i am failed to upgrade it, and showing incompatibility issue. You are requested to please latest firmware of AP7722 and AP7722A.
MS
Hi David,
Your ATS is at the latest firmware for both the ATS Controller (v1.9) and the Network Management Card firmware inside the ATS (AOS 2.6.4/application v2.6.1). The firmware you are trying to apply is for newer units only like AP7722A, AP7750A, AP7730, etc and basically all Rack ATS SKUs EXCEPT AP7722, AP7750, and AP7701.
Dear team,
I have apc rack ATS of AP7722A and its installed FW is apc_hw02_aos357_g2ats357.exe and it was the old version and according to latest updates new version is apc_hw02_aos392_g2ats392. I have tried to upgrade directly but it is showing uncompatility with OS and so your kind support is required in this regard.
Waiting for your prompt response.
Regards
MS
Hi Muhammad,
I'm assuming you've tried using the firmware upgrade wizard to automate the upgrade process. There shouldn't be any issue to go right from v3.5.7 to v3.9.0, I would recommend to try manually updating the firmware via FTP. We have instructions on how to do so here: https://www.apc.com/us/en/faqs/FA156047/
Follow the section labelled "Manual via FTP", and the specific instructions regarding "NMC1".
Dear Matt,
MS
