Intel Macintosh OS 10.5 (Leopard) an APC UPS fix.
  • Intel Macintosh OS 10.5 (Leopard) an APC UPS fix.
5060
139
Erasmus_apc
Sisko Erasmus_apc
112
Posted: ‎2021-06-30 07:08 AM . Last Modified: ‎2024-03-07 11:28 PM
1082
I thought this information may be helpful to those of you having difficulties connecting an Intel Macintosh running OS 10.5.x (Leopard) to an APC-UPS. I was attempting to connect a MacMini to an APC Back UPS ES350R and I was unable to locate a version of PowerChute that supports OS10.5. When I installed the Intel based version, PowerChutePE_v1.3.4 (OS10.3.9-10.4.1) the system wouldn’t shutdown on battery backup. The solution I came up with to correct this problem was to install then immediately uninstall PowerChutePE_v1.3.4 and then configuring the device through Apple's build-in UPS support. By uninstalling PowerChutePE_v1.3.4 with the APC provided utility, uninstall_pcpe.command I removed the conflicting software but the USB driver remained allowing me to access the device through Apple’s build-in UPS support software.
APC-UPS 10.5 fix
1. Install then uninstall PowerChutePE_v1.3.4
2. Configure Apple’s build-in UPS support:
System Preferences > Energy Saver > Settings For: UPS
Good luck!
Brian J.
  • back-ups
  • leopard
  • mac
  • management
  • os
  • PowerChute
  • shutdown
  • snow
  • software
  • windows
  • x
If Only I could at least have the problem of Seeing the UPS settings which should be available in the Energy Saver Panel.... alas, I get no UPS option.
Here is a copy of what I wrote to Support (a rather difficult process as well)
I am aware that there is not a Powerchute version available for Mac OS Leopard ... so I have been using the Energy Saver Panel... all was working fine. I suppose the problem started when I upgraded to 10.5.7 (or .6) The Energy Saver Panel does not show the UPS settings menu choice at all.
I have checked the USB connection and I can see the Back-UPS ES 750 USB connection in the System Profiler.
Just to check I also re-installed PowerChute (latest version)... which then gives me a dialog "No UPS device could be found..." something like that. Again... my Mac is reading the USB port connection to the UPS.... see System Profiler Info below...
I have since used the Uninstall script to remove PowerChute but am still having problems with the UPS not showing up in the Energy Saver Panel.
Thanks for your help.
Terry
System Profiler Info:
Back-UPS ES 750 FW:841.I2 .D USB FW:I2:
Product ID: 0x0002
Vendor ID: 0x051d (American Power Conversion)
Version: 1.01
Serial Number: 3B0827X02700
Speed: Up to 1.5 Mb/sec
Manufacturer: American Power Conversion
Location ID: 0x3a200000
Current Available (mA): 500
Current Required (mA): 2
I do hope these problems are solved soon.
Terry
Product ID: 0x0002
Version: 1.01
