Input Phase Selector switch
  • Input Phase Selector switch
5060
142
dario_ramos_apc
Lieutenant JG dario_ramos_apc
Lieutenant JG
Posted: ‎2021-06-30 02:12 AM . Last Modified: ‎2024-03-10 11:58 PM
1746
Hi all
Please let me know what happens if I put the Input Phase Selector Switch not in accordance with the power feeding:
- Connect the UPS to a three phase mains and put the switch in "1"
- Connect the UPS in single phase and put the switch in "3"
Can the UPS become damaged because of this mismatch?
Please consider SURT10000XLI UPS.
Thanks in advance
  • apc
  • hardware
  • power
  • smart-ups
  • ups
Posted: ‎2021-06-30 02:13 AM . Last Modified: ‎2024-03-10 11:57 PM
I dont have any experience with this issue.
1. But as my knowleage, the switch selection in "1 "will make a solid connect between 3phase input. You will got the short - circuit in case apply the 3 phase to this selection.
Why ?
Rectifier only provide convert from AC to DC.
The IGBT (or SCR in each phase is sized ~ 10kVA/3). in 3:1 mode, it's ok
In the 1:1 mode, the L1 can't support enough capacity so it's will make a solid 3 phase. L1, L2, L3. (The bypass only take from L1).
2. If you put the single phase to but select 3 phase. It's won't have any issue (this is site wiring failure alarm, or make the Input outside of tolerat - run battery).
Replies 5
dario_ramos_apc
Lieutenant JG
Hi
Thanks for your post but you are wrong.
Your speech assumes that the "input selector phase switch" is a power one and it is not. It is a signal switch, and acts to the control like a setup parameter. It has influence on the UPS behavior and, I think, on the way control modulates input switching when supplying the internal inverter from AC mains.
The UPS doesn't have a controlled switch - IGBT module - per phase. Instead it has a bridge rectifier per phase (two bridges in parallel on phase L1 to support 1:1 running). IGBT modules are assembled after input rectification.
dario_ramos_apc
Lieutenant JG
Definitely no one knows something about this?
dario_ramos_apc
Lieutenant JG
Hi all
Are you in vacations
dario_ramos_apc
Lieutenant JG
Posted: ‎2021-06-30 02:12 AM . Last Modified: ‎2024-03-10 11:57 PM
Hi there
Pleeeeeeease can you leave here any support to my inquiry?
I have one SURT10000XLI that was connected to a three phase system with the phase selector switch in the position "1".
The input/battery converter - PFC or DC/DC from batteries - became damaged. One IGBT module was broken.
I would like to know if those things - switch position and converter damage - can be correlated.
Why ?
