I replaced battery, but still RED / GREEN led alternating colors
Send InviteCancel
Posted: 2022-07-1701:30 PM
I took this indicator to mean a weak battery. As such, I replaced the battery, but I get the same indication. Could it be bad contacts to the terminals or something else? Do I need to discard the UPS and return the replacement battery?
Thank you for reaching out to the SE Community, my name is Jon and I will assist you with this query. I'm sorry to hear about the issue that you are having. Will you be able to share the model number of your unit?
