How to update PDU firmware from Linux
Showing results forΒ
Did you mean:Β
  • How to update PDU firmware from Linux
5060
Spock Teken
127
Erasmus_apc
Sisko Erasmus_apc
112
Posted: β€Ž2021-06-28 02:43 AM . Last Modified: β€Ž2024-02-14 10:50 PM
2260
We are a 100% linux shop. How do I update our PDU firmware from linux? I downloaded the latest update 3.5.5 but it appears to be an EXE. Is there anyway to extract out the binary blob from the exe and install it via tftp or scp or something?
Message was edited by: scottb - corrected typo in title
  • data_centers
  • firmware
  • linux
  • pdu
  • software
Posted: β€Ž2021-06-28 02:44 AM . Last Modified: β€Ž2024-02-14 10:49 PM
Replies 7
Hmmm I may have bricked my pdu 😞
I uploaded apc_hw02_rpdu_355.bin via ftp and all went fine. The pdu restarted before I could upload apc_hw02_aos_356.bin. Now I get the following on the web interface:
Error: The application was not able to load.
You are attempting to access an APC device.
There was a problem loading the application. Please login to the device via telnet for more details.
I logged in via telnet and it says similar things like "app not running..."
I tried uploading the aos binary but it doesn't appear to be sticking. Any ideas?
Hi Scott,
If your PDU has an IP address and FTP enabled, you can simply upload the aos_xx.bin file to the PDU and it will do the rest.
Hope this helps.
thanks... I figured out how to extract out the bin files. unzip to the rescue. It was as easy as unzip blah.exe
Message was edited by: scottb - I used unzip not gunzip
It is important to enter binary mode after you start the FTP session before attempting to load either the AOS or APP files. The AOS file should be loaded first and you should logout of the FTP session after uploading this AOS file. Give the PDU about a minute to allow it to reboot, then establish the FTP session again, enter binary mode and upload the APP file. After logging out the PDU will reboot again. I usually login via telnet after uploading both files and there is a section called Stat on the first page that pops up. There should be three letters next to the word Stat and they all should have pluses.
Stat: P+ N+ A+
If they are all pluses the firmware was loaded properly.
I was apparently too impatient. I didn't expect to be cut off from ftp after the first upload. Then the ssh connection just hung (probably because of a slow cpu). I ftp'd in the other bin file and after the auto-reboot I was good to go. Thanks all.
The progress on the electrical lines at the Fukushima Jeremy Scott Dai-ichi nuclear power plant was a welcome and Jeremy Scott Shoes significant advance Tuesday after days of setbacks. With the power lines connected, officials Jeremy Scott Shop hope to start up the overheated plant's crucial cooling system that was knocked out during the March 11 earthquake Jeremy Scott Adidas and tsunami that devastated Japan's northeast coast. Tokyo Electric Power Co. warned that workers still need to check all equipment Jeremy Scott Wings for damage first before switching the cooling system on to all the reactor units β€” a process that Jeremy Scott JS Wings ould take days or even weeks. Late Tuesday night, Tokyo Electric said lights went on in the central control room of Unit 3, but that doesn't mean power had been restored to the cooling system.
Β
