Posted: 2024-04-12 02:23 AM
I'm looking for ntp server change instruction with PCNS V4.4.3
Because, default NTP server looks like access to public sites, our network team regarding change ntp server to internal runing ntp server.
How can i change PCNS NTP server IP address?
Posted: 2024-04-17 07:37 AM
Sorry I misspoke earlier. By default the NTP service is inactive when PCNS VM is installed. Someone locally has to enable it.
To stop the VM from using NTP enter the command timedatectl set-ntp off
If you want to permanently disable NTP on the VM enter the command systemctl disable chronyd systemct stop chronyd
If you want the VM to use an internal NTP server edit /etc/chrony.conf
Comment out the line pool 2.cloudlinux.pool.ntp.org iburst
add the line server <IP address of the NTP server>
Example
#pool 2.cloudlinux.pool.ntp.org iburst
server 192.168.0.11
restart the service
systemctl restart chronyd
Posted: 2024-04-15 09:36 AM . Last Modified: 2024-04-17 06:45 AM
The PCNS 4.4.3 VM is AlmaLinux. See How to change AlmaLinux NTP client.
https://linuxconfig.org/how-to-configure-ntp-server-and-client-on-almalinux
BTW: By the NTP service is inactive. It must be enable locally.
Posted: 2024-04-16 01:22 AM
Thanks BillP your comments and suggestion.
Yes I know and enabled synchronize VMWare tools NTP clients as below
Our Network team told me, those PCSN server NTP protocol access to out side and blocking.
So, I review existing status NTP service access, looks like access to outside
I review exsiting configuration file "/etc/chrony.conf"
Existing nothing any NTP server settings, should I add "Server local NTP server IP" and restart service?
Best Regards.
Example
server 192.168.0.11
restart the service
Posted: 2024-04-18 01:13 AM
Thanaks BillP your quick reply and more explanation.
I just updated and confirmed access ntp to internal.
I enabled both time synchronize VMWate tools and ntp this time.
Is it not nessesary enable both option, only enable time synchronize via VMWate tool would be enough?
Anyway, thanks your help and I'll take note for next time setup PCNS include this operation
Posted: 2024-05-22 01:43 AM
"PCNS V4.4.3" I need too this version. You are welcome to share this version. for the community? email tunik(AT)bigmir.net. Thank you very much.
