Posted: β2021-06-30 12:57 AM . Last Modified: β2024-03-11 03:34 AM
The settings below in the Shutdown section. I would like to confirm / check that the following:
1. It (the settings) will apply to all the servers it connect to
2. The shutdown of the server will only start after the low battery occurs at the UPS (after a continuous period of power failure).
3. How is low battery determined?
4. What's Shutdown Delay and Max. Required Delay?
5. And the rest of the terms : Sleep Time, Min. Battery Capacity and Return Delay?
-------------Settings--------------
Shutdown
Start of Shutdown
Low Battery Duration: 02 minutes
Shutdown Delay: 180 seconds
Maximum Required Delay: 2 minutes
Basic Signaling Shutdown: Disable
Duration of Shutdown
Sleep Time: 0.0
End of Shutdown
Minimum Battery Capacity: 00%
Return Delay: 00 seconds
-------------------End of Settings----------------
Thank you.
Daryl
Posted: β2021-06-30 12:58 AM . Last Modified: β2024-03-11 03:34 AM
hello,
someone gave me the attached document - take a look there. and also, all of the delays and stuff are explained in the help file right in PCNS, probably better than i can retype here. let me know if you have questions with that.
hello,
Please provide the following details:
Not to hijack this thread but like the OP I had similar questions recently when setting up my NMC and PCNS for a 3 server ESXi cluster. i picKed a winna could you clarify a few things for me?
I am trying to figure out exactly when the NMC will send the shutdown signal to the PCNS clients. I have a pair of SMT3000RM2U in a redundant configuration and load is distributed almost evenly between both. So to calculate how long the servers would run for before receiving the shutdown signal would you take (runtime remaining) - (low battery duration) - (Maximum required delay + 2 mins) - (power off delay)? So for me currently that would be 17 - 8 - (2+2) - 1 = 4 mins of server run time before it receives the PCNS shutdown. Which means 11 minutes of shutdown time (I am realizing that is far too conservative if my calculations are correct).
My second question is do I need to do anything in PCNS under Configure Events to have the server shut down properly? The only thing I see that makes sense is Runtime:Exceeded. I can have that checked on to shut down the PCNS operating system.
Thank you in advance for assisting me with these questions.
Rob
hello,
