Help finding replacement batteries
Send InviteCancel
Purchase via third party such as battery mart etc or save more finances and rebuild the pack yourself.
You simply need to reuse the cables, fuse holder, and apply some double sided tape. The RBC takes two High Rate (HR) 12 VDC 9 amp hour cells wired in series to create a 24 VDC cartridge.
The vast majority of the quality cells are supplied by CSB which you may buy directly from:
