Share Your Feedback โ€“ Help Us Improve Search on Community!
Galaxy 3500 and AP9631
Showing results forย
Did you mean:ย
  • Galaxy 3500 and AP9631
Posted: โ€Ž2021-06-26 05:06 AM . Last Modified: โ€Ž2024-03-19 01:09 AM
2508
Hi everybody,
The UPS is running fine, the card is configured, answers to ping, but when I try to access it by IE, it doesn't display the tabs for the UPS parameters. Says unknown UPS. So: faulty card, or faulty interface between UPS and comm card? Is it a big deal to fix the issue?
Thank you
  • Data Center & Facility 3 Phase UPS
Posted: โ€Ž2021-06-26 05:07 AM . Last Modified: โ€Ž2024-03-19 01:08 AM
hi mihail,
you need to upload an AOS, then one of the application files. if you are using a Smart UPS or Matrix UPS with AP9606, you should upload the AOS and then the sumx file, or if its a symmetra 3 phase, do sy3p, etc
You cannot just load an AOS by itself.
Replies 20
Hi everybody,
Thank you
no problem ๐Ÿ™‚ sounds like a configuration issue. please let us know if you need anything else.
Hi again,
I have already tried to re-insert the card, that very night. Also, I have pull out the power module and replace it. It just didn' t work. Now the thing is that no one is hooked to that UPS. And I don't know if that connection will be ever used. We'll see.
By the way, here is another issue; customer has a bunch of old Symmetra Power Array( single ph 16kVA). They are all tied to the network, but they do not send alerts whenever problems appear.(like e-mail notifications....bla bla)
Do you think that a firmware upgrade could solve the issue? If Yes, what would be the right ".bin" for the UPS mentioned above?
Regards.
Mihail
Posted: โ€Ž2021-06-26 05:07 AM . Last Modified: โ€Ž2024-03-19 01:09 AM
ok great!
hi i looked.
i see
; American Power Conversion
; Network Management Card AOS v5.1.3
; Smart-UPS & Matrix-UPS APP v5.1.3
this is indeed the correct firmware. you are correct - galaxy 3500 is very similar to a Smart UPS VT so it is considered a Smart UPS firmware wise.
This is the correct firmware for this UPS. You can try reseating the card in the slot on the UPS. other than that, I am not sure. i am not that familiar with this particular UPS. if you'd like, i can give you a newer firmware to try but i am not sure if it will solve the issue.
my recommendation would be:
1.) try reseating NMC in the slot on the UPS
2.) try new firmware application I can send you
3.) we will have to talk to someone that supports this UPS in particular to see if anything else can cause no communication between the NMC and UPS that we can try.
hi mihail
hmm, i am not sure what else the issue could be on the galaxy. it could possibly be a problem with the NMC itself if you did swap out the power module but i am not 100% sure.
on the symmetra power array, you are using an AP9606 Web/SNMP card. this card is 10+ years old and uses a different firmware than the NMC2 in the galaxy UPS. the firmware versions you provided in your attachment are already indeed the latest versions. unfortunately, the old AP9606 did not support config.ini export since it is so old so i cannot check the email configuration. we'd have to check the email configuration under the Network Menu-> Email, if you have to access it via the console or we can do it via the web page if you can get to that.
also, i see the card has been up for 167 days. i don't think it would hurt to reboot the card as i've seen that solve the issue too. you can do this under system->tools->reboot. this will not affect the load and only reboot the card.
also, did this just stop working or did it never work?
Hello there,
Sorry for the break but I have been out for some work,
To make to story short, this customer had a very smart guy for IT. Ever since they fired him, the problems started to flow like Niagra falls. The cards worked in his era, now......Now, I did reboot every single bloddy card, checked all the parameters, they are telling me that the cards are fine, they just don't send alarms. I shall think to something till next april I still think they problems in in their yard.
Thank you
By the way,
Where can I fond the latest rev for the firmware for AP9606?
Thank you,
Mihail
Hello again,
Thank you for the info. If my memory is still ok( knowing that today I am adding another year :(( ), we might have one of this old beast somewhere hidden in our warehouse. I shall give it try before going to the customer.
Thank you for the support and valuable answers.
Mihail
Posted: โ€Ž2021-06-26 05:07 AM . Last Modified: โ€Ž2025-05-30 12:11 AM
ftp://ftp.apc.com/apc/public/hardware/webcard/firmware/security/v326b/
you can download the AOS file then whatever application you are using.
follow the manual FTP instructions
hi mihail,
Hi there Angela,
Thank you for the answwer. So,what I need to upload is only the aos.bin file. That should solve my problem.
Ciao.
Mihail
Hello Angela,
I did solved this issue yesterday. remember.. a card not respoding/ faulty from the start-up. Well I went on the apc software and download the latest firmware, all cool now, it is fix. no problem during or after the "surgery".
Thank you Angela.
Mihail
you're welcome!
sounds like maybe the wrong firmware is loaded, if you recently upgraded it.
either way, can you please provide the information from the Administration Tab->General->About from the web interface?
thanks.
No, I did not do any upgrade, it is a new UPS installation, it happen right on startup. :((
can you still tell me what you see under that Administration tab->General->About screen please?
so nobody can log in or access the card remotely?
I have a chance to see it tomorrow. I shall let you know
Thank, you
you're welcome!
ย
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2025 Schneider Electric
