Galaxy 300 G3TH20KHB2, end of battery life... Can I connect third party battery pack of 150 ah each block
  • Galaxy 300 G3TH20KHB2, end of battery life... Can I connect third party battery pack of 150 ah each block
5060
142
Owenrrr
Owenrrr
Cadet
Posted: ‎2024-06-12 10:07 AM
503
KarimEissa
Commander KarimEissa Commander
Commander
Posted: ‎2025-01-31 01:01 AM
No,you can not,it is only done if the UPS frame supports external battery solution, beside 150 Ah is a very high battery capacity ,the UPS charger will take a huge  recharge time to charge those batteries and may leads to charger board failure ,we had already battery runtime guidance for external batteries solution  since the unit supports internal batteries G3TH20KHB2 then you need to replace the internal battery blocks with the same specs and vendor
Karim
KarimEissa
Commander
Karim
