Posted: 2023-12-25 08:55 AM
Hello everyone,
I hope this message finds you well. I'm in need of some assistance related to my Galaxy 300. Since the forum was migrated to the SE website, I lost access to the necessary software. Specifically, I require the latest firmware for the AP9631 card and the UPS tuner software to replace batteries in a 10-year-old UPS that's still functioning well.
I would greatly appreciate any help you could provide.
Thank you in advance.
Kind regards,
Sebastian
Posted: 2024-06-16 03:48 PM
Up
Posted: 2024-06-18 12:23 AM
Good Morning.
Tuner is only for SE FSR's and their partner FSRs. If you have a way to obtain Tuner im listening. I believe that the battery alarm can be cleared using the NMC. I have not tried this method before. With your unit having a NMC you can try this method by dpierce4776
"Thant depends on which NMC you have and the firmware. If you have the 9640 or 9630. Then under UPS there is a spot for battery alarms timing. Put a -1 on both spots to clear the alarm"
Please let me know if this works, I have a unit 600km away that needs resetting. Going without a proven solution is not economical.
Let me know if it works.
Posted: 2024-06-27 11:19 PM
Good Morning
I had the opportunity to test the canceling of the Galaxy 300 via the NMC below.
Unfortunately there is no option using the NMC to clear the battery alarm.
Posted: 2024-06-28 10:57 PM
Hi everyone,
I also can’t reset the alarm via NMC. It seems that the NMC functionality in the Galaxy 300 is quite limited. It lacks features such as:
• Changing output voltage
• Triggering a battery test
• Triggering a calibration test
I replaced the battery string myself, thoroughly checking each one for internal resistance and voltage. The battery string is working perfectly, but since I’m not a Schneider partner, I don’t have the software to adjust the charging current and clear the battery alarm. I’d be happy to establish such a partnership and would appreciate guidance on the official process.
If that’s not possible, could someone with the software assist remotely?
Thanks in advance!
Posted: 2025-01-30 04:57 PM
Is there anyone here who can help me remotely?
