Floor lamp, at low brightness, causes issue with a SUA1500?
Send InviteCancel
Posted: 2021-06-3003:14 AM. Last Modified: 2024-03-0804:45 AM
I have a 15A circuit to which is connect a floor lamp, with two 72W Halogen bulbs (new type), and two SUA1500. When the floor lamp is set to max brightness there's no issue. When I turn the lamp to its lower brightness setting one of my APC units will make an odd noise. I can't really describe the noise other than it's similar to a constant low level static. If I turn the floor lamp to its full brightness setting the noise immediately goes away. I can repeat it every time. Any idea what could be going on?
