Discharge Battery Alarm , what should I do ?
  • Discharge Battery Alarm , what should I do ?
Posted: ‎2021-06-29 07:49 AM . Last Modified: ‎2024-03-12 03:20 AM
3029
We are using Smart-UPS 3000 RM with 9630 Management card.    I got the following message.  I tried to replace with a new battery and cold reboot the UPS , but still get the message of  "the battery power is too low to support the load" and  "Discharged Battery" Alarm
What can I do ?
Ok, it is likely that the UPS needs to be calibrated. See how your runtime reported is 3 minutes - and you have a very low load? This likely did not update properly after you replaced the batteries a month ago.
Essentially, you should attempt a runtime calibration which you can issue via the Network Management Card under UPS->Diagnostics. If this does not work properly, let me know. We'll need to attempt a few other steps and for those other steps, then I need to know the exact SKU of the UPS from the rear of it on the white sticker please.
Lastly, as more of a supplement, there is more explanation here (Why are the battery charge LEDs flashing on a Smart-UPS? | FAQs | Schneider Electric US). We may try the other steps outlined here but we may do one that is not mentioned there.
My first thought is to check the following settings:
  • Verify the UPS runtime under the UPS->status or overview menu (is the value normal?)
  • Check under UPS->Shutdown and let me know what the low battery duration value is set to. (did you recently change this)
Then:
  • How old are the batteries?
Let's start there. This may be just a setting configuration issue or if the batteries are lower, you may just have low runtime available now.
Alternatively, I can read this information from the event.txt, data.txt and config.ini files if you want to provide those. (Instructions here -> How can I download Event, Data, Configuration, and Debug files from my Network Management Card? | FA...)
Hi Angela,
Thanks for your assistance.
Status of the UPS is as below:
Last Battery Transfer:Due to software command or UPS's test control
Internal Temperature:24.7°C
Runtime Remaining:3min
Power
Input Voltage:117.3 VAC
Output Voltage:117.3 VAC
Frequency:60.0 Hz
Load
Load Power:9.1 %Watts
Apparent Load Power:9.1 %VA
Load Current:2.3 Amps
Battery
Capacity:100.0 %
Battery Voltage:55.08 VDC
External Batteries:0
Low Battery Duration:        2 mins (never be changed, by default)
How old are the batteries:  New battery , Just changed it at last month.
The event.txt, data.txt, config.ini are compressed to a zip file at below link
http://speedy.sh/7BDbt/10.10.74.182.zip
