Posted: 2021-06-26 04:52 AM . Last Modified: 2024-03-19 01:18 AM
Hello guys,
I have to prepare a general template for Data Centers, that takes into accounts most of the options available.
I require some information relating to these questions:
What types of rack options are available to data center users? Data centers come with U space, what options are there in this case. Also what type I will use depends on what? Power load required?
As I increase the number of racks in a DC, what other things i will have to increase? Also to what level will the
racks be able to run with the same settings?
Thank you,
I'll come up with other questions next time.
Posted: 2021-06-26 04:53 AM . Last Modified: 2024-03-19 01:18 AM
Hello guys,
Thank you,
Umair,
Ah, if it was that easy. (people like me would be out of work)
There are dozens of rack options and hundreds of server options. Everything needs to be taken into consideration when designing a data centre.
You won't find a simple template for Data Centres, however, there are software systems that try to calculate the outcome of "what if" scenarios.
There are many data centers that has different set-ups its better if you will require to them.
HI,
Check with some data center service provider,
[San Diego Colocation Data Center|http://www.castleaccess.com]
Hello guys,
Thank you,
