Could not login to AP9640 on SMT3000RMI2U
  • Could not login to AP9640 on SMT3000RMI2U
5060
139
Erasmus_apc
Sisko Erasmus_apc
112
Daniel-73
Daniel-73
Cadet
Posted: ‎2024-04-29 12:45 AM
1041
Hi Support,
I have problem accessing to Ap9640 console connected to SMT3000RMI2U ups. I am able to ping to Ap9640 and receive email alerts but just not able to access to the console. Not sure what was stopping me from accessing on the browser.
Before this, the UPS was configured by the installer using direct Lan connection via laptop.
Any specific ports needed to be opened or any settings needed to be tweak on Edge browser?
Thankyou
Replies 6
Kirk
Posted: ‎2024-04-30 05:07 AM
1025
What do you see on the web browser using the NMC IP Address?!? What error codes are declared on the page?
Have you tried connecting to the NMC via SSH? I ask because HTTP / HTTPS may be disabled by the installer.
Report back what you observe as to the two questions posed. 👍
dpierce4776
Lt. Commander dpierce4776
Lt. Commander
Posted: ‎2024-05-01 09:32 AM
Also make sure you are using 9600 8 1 none none on your terminal settings.
Daniel-73
Daniel-73
Cadet
Posted: ‎2024-05-01 06:26 PM
In response to Teken
957
browser returned error "hmmm, cant reach this page" x.x.x.x ip took too long to respond
Before i changed to correct nmc ip under a difft vlan, I able to login to nmc but email cant get thru bcos later i realised i entered a wrong ip under a difft vlan. Now after I entered a correct Ip, email can get thru but just that can't login to nmc via browser. I suspect its the firewall that was blocking & I need ot know what ports nmc are using.
Thankyou
Kirk
Posted: ‎2024-05-02 04:52 AM
In response to Daniel-73
Keep this simple and connect directly to the NMC with a laptop. If you can’t connect using a cross over cable this has nothing to do with a firewall.
The NMC ports are the standard ones unless they were changed for HTTP / HTTPS (80/443).
Use the APC Serial cable and see if you can SSH into the system assuming it’s enabled. You may find HTTP / HTTPS is disabled.
Lastly, you’ll want to check the TLS 1.1, 1.2, 1.3 encryption is set correctly and your web browser is defined as well for web access.
dpierce4776
Lt. Commander
Posted: ‎2024-05-06 08:23 PM
891
Can you ping the device now that it is on the new VLAN?
Daniel-73
Daniel-73
Cadet
Posted: ‎2024-05-08 05:50 PM
In response to dpierce4776
Yes able to ping but just not able to login thru NMC web console. Its something to do with the firewall blocking. Anyhow i plug my laptop to same vlan as the nmc and able to login to webconsole. Only https & ssh is enabled.
We can close this. Thanks
