Ask Me About Webinar: Data Center Assets - Modeling, Cooling, and CFD Simulation Join our 30-minute expert session on July 10, 2025 (9:00 AM & 5:00 PM CET), to explore Digital Twins, cooling simulations, and IT infrastructure modeling. Learn how to boost resiliency and plan power capacity effectively.Register now to secure your spot!
Apc1- 9619 interface card, not able to load web interface.
Send InviteCancel
However, when I try updating one device (let's call it apc1), I get the following error message on the web interface: "Error: The application was not able to load. You are attempting to access an APC device. There was a problem loading the application. Please login to the device via telnet for more details."
But interestingly, when i did the exact same procedure previously on another device (apc4), the update was successful, and i was able to access the web interface without any issues.
So what have i done wrong?
Any help troubleshooting this would be greatly appreciated!
Posted: 2024-09-1106:51 AM
So it turns out that in order to update the UPS firmware, I needed the default username and password (apc), even though I had already provided the new user and password. I assume there's some sort of check hardcoded into the script.
Using Telnet, I was able to reset the password, run the firmware update again, and this time it completed successfully, with the web interface returning. It was a really simple solution to what I initially thought was a major mistake on my part.
Maybe next time, I won't panic so quickly. Thank you.
This is a heading
