An automatic voltage regulator (AVR) relay fault exists
  • An automatic voltage regulator (AVR) relay fault exists
Posted: ‎2021-06-28 02:43 AM . Last Modified: ‎2024-02-14 10:50 PM
22454
Is this a call to replace the ups all together or is there something that can be done?
Also I was wondering if what is in the log, that i will attach, is an issue with the power input or if the relay going out is causing these errors?
link to logs (the times and dates are off)
http://pastebin.com/gFyHb3Gu
thank you in advance for any help you may provide.
  • apc
  • avr
22440
What is the model of your UPS?  Usually, depending on your UPS, an AVR fault deems a replacement necessary.  The AVR is what is compensating for the low input voltages noted in your logs (which if true is an input/utility power problem).
If you can let us know the UPS model and serial number, we may be able to instruct you on a troubleshooting procedure to try and clear the fault.
Posted: ‎2021-06-28 02:44 AM . Last Modified: ‎2024-02-14 10:49 PM
Jordan.
thanks for your suggestion. after following your troubleshooting steps it did finally reboot and for about 4-5 seconds i thought it would be ok but then it clicked and gave the p.06 error once again. I am reaching out to APC for warrenty as the unit is within its first two years of service. ( we installed it about 1 year ago.
I will let you know what we determine.
Replies 7
22441
the model is a Smart-UPS X 1500 and the serial is AS1105223006
22441
I would recommend what we call a braindead procedure:
1- Turn off the UPS
2- Unplug all load
3- Unplug the unit from utility
4- Disconnect all batteries
5- Hold down the power button for about 20 seconds
6- Reconnect the batteries, unit, and load
7- Bring the unit back online
If the fault clears, that is great, but if it does not, it is a true AVR fault and the UPS needs replacement.
Jordan.
federico.fiordoliva
federico.fiordoliva
Cadet
Posted: ‎2021-11-12 06:54 AM
In response to BillP
22184
Hi all,
i have the same ploblem, my ups is Samrt-UPS 1000 va.
Display report P.06 and red led is active.
Serial n. as2034360936
Model: SMC1000IC
The output was blocked.
Can you help me?
pgorman
Crewman pgorman
Crewman
Posted: ‎2022-09-01 05:57 AM
In response to federico.fiordoliva
You are most certainly going to need a replacement unit VRM or what apc calls AVR is basically a chip that regulated and evens the voltage going thru it so the equipment on the other side is not damaged. It is going to be cheaper to get a new ups or warranty/ maintenance claim.
Abass_apc
Abass_apc
Cadet
Posted: ‎2024-03-07 11:39 PM
Smart-UPS 1000
s/n.  AS1044212049
