Adding users via CLI
  • Adding users via CLI
Posted: ‎2021-06-29 05:46 AM . Last Modified: ‎2024-03-13 12:31 AM
3677
I can successfully add users via the CLI:
apc>user -n bob -pw wezapu -pe Administrator -e enable
E000: Success
apc>
And modify the existing Device and Read-Only users:
apc> user -n Device -pe Device -pw secret -e enable
E000: Success
apc>
But I am not able to modify the default Administrator account
apc>user -n apc -cp apc -pw secret -pe Administrator -e enable
E102: Parameter Error
Usage: user --  Configuration Options
    user -n [-cp  ] (Req. For Super User Account)
                   [-pw  ]
                   [-pe                            Outlet>]
                          (user permission)
                   [-d   ]
                   [-e   ] (Access Enable)
                   [-st  ] minute(s)
                   [-sr  ] (Serial Remote Auth. Override)
                   [-el  ] (Event Log Color Coding)
                   [-lf  ] (Export Log Format)
                   [-ts  ] (Temperature Scale)
                   [-df                            dd-mmm-yy | yyyy-mm-dd>] (Date Format)
                   [-lg  ] (User Language)
                   [-del ]
                   [-l   (shows current user list)]
apc>
Can you see what I am mistyping?
apc>about
E000: Success
Hardware Factory
Model Number:           AP8858NA3
Serial Number:          ZA1510010179
Hardware Revision:      02
Manufacture Date:       03/03/2015
MAC Address:            00 C0 B7 E8 A6 4A
Management Uptime:      0 Days 0 Hours 31 Minutes
Network Management Card
Model Number:           AP9537
Serial Number:          ZA1509012336
Hardware Revision:      05
Manufacture Date:       02/28/2015
Application Module
Version:                v6.4.0
Date:                   Jan 21 2016
Time:                   17:42:56
APC OS(AOS)
Version:                v6.4.0
Date:                   Dec 18 2015
Time:                   15:04:27
APC Boot Monitor
Version:                v1.0.8
Date:                   Apr  8 2014
Time:                   10:59:40
apc>
--sk
  • password
Ahh, I see, no need to 'enable' the Administrator user, if it is already enabled.
Yup, that works, thank you.
--sk
Is the user enable prior to you entering the change password command? If so you need to enter
--sk
