Accept Untrusted SSL Certificates
Send InviteCancel
Posted: 2021-06-3006:11 AM. Last Modified: 2024-03-0801:25 AM
I can't seem to get past having to check this check box on my Powerchute Network Shutdown setup. The cert on the NMCs are signed by a local CA, which I jammed into the cert store via keytool and the -cacerts switch. I see the NMC certs in the powerchute-keystore but the software will not communicate with the UPS unless I check "Accept Untrusted SSL Certificates." What am I missing here?
