AR3140/3340 Cable partition & ladder options.
  • AR3140/3340 Cable partition & ladder options.
5060
142
Posted: ‎2021-07-12 05:05 AM . Last Modified: ‎2024-01-31 02:57 AM
944
I'm having trouble figuring out exactly which part numbers are required when mounting the AR8165ABLK Cable ladder and running cables across two rows of cabinets facing each other.
AR8571, AR7209, AR8172BLK, AR8173BLK?
Lee
Hello Lee,
AR8165ABLK is a 10 foot section of 12" cable ladder with ladder attachment kit. If you are attaching this to either a trough or partition the AR8165ABLK has everything you need. Please see the installation manual: http://www.apc.com/salestools/ASTE-6Z6K6V/ASTE-6Z6K6V_R2_EN.pdf
If you need extra attachment kits because you are cutting the ladder into sections please see AR8166ABLK: http://www.apc.com/salestools/ASTE-6Z6K6V/ASTE-6Z6K6V_R2_EN.pdf
If you are not connecting the ladder to a trough or partition you can use AR8186: http://www.apc.com/salestools/JKUR-7HAMSC/JKUR-7HAMSC_R1_EN.pdf
Hello Lee, included with the AR8165ABLK you will have hardware to attach to the side of a trough or partition: http://www.apc.com/salestools/ASTE-6Z6K6V/ASTE-6Z6K6V_R2_EN.pdf
Or, you can use two sets of AR8186: http://www.apc.com/salestools/JKUR-7HAMSC/JKUR-7HAMSC_R1_EN.pdf
Thanks, but what are the correct part numbers for the ladder kit to attach?  All the items I quoted or just some?  I'm uncertain the correct list of part numbers to mount at the top of the rack for cable management.
Hello Lee,
