APC SNMP Card APV9601 IP configuration done but SNMP !P does not open in Browser.
  • APC SNMP Card APV9601 IP configuration done but SNMP !P does not open in Browser.
AwaisKhalid_apc
Ensign AwaisKhalid_apc
Ensign
Posted: ‎2021-06-30 07:36 AM . Last Modified: ‎2024-03-07 10:56 PM
5951
APC SNMP Card APV9601 IP configuration done but SNMP !P does not open in Browser. kindly Help me about this how i can resolne this issue.
Awais Khalid
Asst Enginner
  • network_management_card
  • smart
AwaisKhalid_apc
Ensign
5949
Hi Tom,
I want to shutdown my UPS When the Battery remains 20%. Plz guide me What would  i do fo that
Mr. Awais Khalid
Awais Khalid
Asst Enginner
Replies 11
Hi
The limitations with the APV9601 are that it does not have web browser UI and the software has to be used and the computer hosting the software must be on the same physical network as the UPSes.
Regards
Matt
AwaisKhalid_apc
Ensign
Mr. Matt  I also installed the UPS Software from CD which is with UPS. I Configure IP. In Software I login but UPS Does not Show is Statics.
Plz Help me about that
Regards
Mr. Awais Khalid
Awais Khalid
Asst Enginner
Hi Awais,
Can you please provide some screenshots of the software so I can fully understand your issue.
Tom
AwaisKhalid_apc
Ensign
Hi Tom,
These are the Screen Shots and Plz guide me about that,
E%2F5%2FhkjASk5LlCiGoaFiQw%3D%3D.pngE%2F5%2FhkjASk5LlCiGoaFiQw%3D%3D.pngoShgDYKN9X1O0nmx7HFcBA%3D%3D.pngoShgDYKN9X1O0nmx7HFcBA%3D%3D.pngcUL9se0JXVgU6%2BDWNOYDXA%3D%3D.pngcUL9se0JXVgU6%2BDWNOYDXA%3D%3D.png
Mr. Awais Khalid
Awais Khalid
Asst Enginner
Hi Awais,
From looking at your screenshots, I can see that you are trying to monitor the UPS by entering the IP address of the SNMP card into a browser. It is not possible to view information from the UPS by entering in the IP address SNMP card.
To monitor the UPS, this is done through the SchneiderUPS monitoring software that comes with the UPS.
Tom
AwaisKhalid_apc
Ensign
Hi Tom,
Plz guide me  What Steps will i do that the UPS monitoring Come through IP address.
Awais Khalid
Asst Enginner
Hi Awais,
It is a limitation of the APV9601, that is not not possible to monitor the UPS through the IP address. There is no way around this.
The monitoring can only be done through the SchneiderUPS monitoring software and this software must be installed on any computer that you wish to monitor it from. The computer must also be on the same network as the SNMP Card.
Tom
AwaisKhalid_apc
Ensign
Hi Tom,
Plz also guide me how to installed PowerChute Software for 1 KVA,2KVA and 10KVA UPS.
UPS Models:- SRV1KIL, SRV2KIL, SRV10KIL
Mr. Awais Khalid
Awais Khalid
Asst Enginner
Hi Awais,
Easy UPS are not compatible with PowerChute. The only software that works with the UPS's you listed above is SchneiderUPS monitoring software.
Tom
AwaisKhalid_apc
Ensign
5950
Hi Tom,
Mr. Awais Khalid
Awais Khalid
Asst Enginner
Tafadzwa
Lt. Commander Tafadzwa
Lt. Commander
Posted: ‎2022-04-04 01:53 AM
In response to AwaisKhalid_apc
Hi @AwaisKhalid_apc
I hope you are doing well.
May you kindly assist with the method you used to Configure the APC APV961 SNMP Card? I have a couple of UPSs using these Cards. I have managed to configure the ones connected to Switches with DHCP however Peer-to-Peer is giving me issues. Using the Schneider UPS Monitoring Software, I cannot pick up the UPS using the default IP Address.
Tafadzwa.
Connecting Devices!
