Posted: 2025-04-10 07:37 AM
Hi all,
I hope I've put this into the right subforum. I have seen questions on these units here.
I have an APC AP7921 unit that I am using to power one device with a current draw of approximately 0.3A. I can understand that the display on the unit will show 0 but I was hoping that the webmenu/telnet would show 0.3A. However, it does not. Does any one know what the minimum draw is before it will start to update this value?
Posted: 2025-04-11 07:19 AM
It’s approximately 0.8 ~ 0.9 amps on the LED display taking into account manufacturing tolerances.
If you place a larger amperage draw greater than 1 amp. The system will begin to show some values.
Keeping in mind neither the LED display / Web UI are very accurate to start with. 🤦♂️
Questions Ask . . . 👍
Posted: 2025-04-13 10:15 PM
Thanks for your response. It's a shame it won't display from 0.1A onwards, but I suppose that's not its main purpose!
I was hoping to just use it as an indicator that the unit was indeed turned ON and drawing an expected current +/-100mA (a wide spec!). No problem though, I already have another method working. Thanks again for your help!
