APC AP7900
  • APC AP7900
Posted: ‎2021-06-28 06:39 AM . Last Modified: ‎2024-03-18 01:13 AM
1392
APC AP7900
Does anyone know how I would reboot the management interface on an APC AP7900 using SNMP? If I telnet/ssh to the PDU, I can do this via the command line with a 3 for System, 4 for Tools, and 1 Reboot Management Interface. I'd like to be able to accomplish the same thing using an SNMP string. If anyone could assist I would appreciate it.
P.S. If SNMP won't all you to do this, would I be able to set a schedule from the command line to do this say weekly?
  • ap7900
  • interface
  • management
  • reboot
  • snmp
try this OID: .iso.org.dod.internet.private.enterprises.apc.apcmgmt.mcontrol.mcontrolRestartAgent / .1.3.6.1.4.1.318.2.2.1
Setting this OID to restartCurrentAgent (1) will restart the same SNMP agent code currently saved in flash memory. Setting this OID to loadAndExecuteNewAgent (3) will enable adapter to load a new agent code into the flash memory and start to execute this new agent code. Bootp/tftp is the default protocol. loadAndExecuteNewAgent is only supported by APC Network Management Cards. Setting this OID to restartWithoutAgent (4) will restart the system and not start the agent. The subsequent time the system restarts the agent will also automatically restart. Setting this OID to resetNetworkAndRestart (5) will set the Boot Mode, IP Address, Subnet Mask, and Default Gateway to defaults, expire any existing DHCP lease and then restart the system. Setting this OID to resetNetworkLeaveModeAndRestart (6) will leave the Boot Mode at the current setting, set the IP Address, Subnet Mask, and Default Gateway to defaults, expire any existing DHCP lease and then restart the system.
I did a SET of 1 on my card for this and you can see in my event log:
01/11/2013 09:51:50 System Network Interface restarting. SNMP user request from X.X.X.X.
