AP8659: Outlet Reading not consistent with below 50W and 0.4A readings
Send InviteCancel
However, due to the squelching threshold, it is not consistent.
Q: Now is there a way to disable this squelching feature and just report whatever reading it received? Cause it can read below 50 Watts:
We are testing on Outlet 22 and 23. Both have the same load, however, only outlet 23 receives a reading. We have repeated the tests on other outlets and it is similarly inconsistent.
