AP7941, 208V, Display is 208V Amp's right?
  • AP7941, 208V, Display is 208V Amp's right?
Posted: ‎2021-06-28 03:17 AM . Last Modified: ‎2024-03-18 04:45 AM
691
Kind of a dumb question,
But just want to verify that the amperage output is reading 208V Amps on this unit...
yeah, i guess you could say that.
amps is just amps. it will be lower at the higher voltage of 208 because of the relationship between volt-amps so that makes sense.
hi,
this PDU is 208 volts AC - meaning it accepts 208 volts and outputs 208 volts.
It is a 30 amp PDU so per electrical code, it is rated for 80% of that so it will warn you of an overload at 24 amps. it uses a L6-30 receptacle though.
hope this helps!
No I just want to verify the display is 208V Amperage, so 10 Amps on the display is about 17 120V power for example.
