Posted: 2021-06-28 05:29 AM . Last Modified: 2024-03-18 03:20 AM
I have some AP7921.
One of these devices shows me "Er" on the display. When I connect with the webinterface I can see the message "+Communication has been lost to the device!+".
The eventlog shows me " +10/06/2010 07:49:37 Switched Rack PDU: Communications lost+.".
The Email with errormessages:
Contact : xxx
http://xxx.xxx.xxx.xxx
Serial # : xxxx
Date: 10/06/2010
Time: 07:49:37
Code: 0x0F08
Switched Rack PDU: Communications lost.
I tried to press the reset button near the display and to reboot management interface.
Both attempts were unsuccessful. What can I do to find and correct the error??
Greetings
Sebastian
EDIT: The load status: Load: 0.0 Amps
Message was edited by: swegener
thanks for your reply. These information I found:
Application Module
Version: v3.7.0
Date: 01/13/2009
Time: 15:30:40
APC OS (AOS)
Version: v3.7.0
Date: 01/13/2009
Time: 14:17:08
EDIT: Maybe this is helpful:
Hardware Revision: B2
Manufacture Date: 08/25/2007
thanks for your help. Apparently it helps to switch off the device. I will check it regulary an maybe I will install the new firmware soon.
Greetings
Sebastian
there is an updated rev available on apc.com if you want - 3.7.3 rpdu
Application Module
Version: v3.7.0
Date: 01/13/2009
Time: 15:30:40
APC OS (AOS)
Version: v3.7.0
Date: 01/13/2009
Time: 14:17:08
