ACRD60xP Unexpected number of active flow controller
  • ACRD60xP Unexpected number of active flow controller
5060
139
Posted: ‎2021-07-09 04:25 AM . Last Modified: ‎2024-02-14 10:22 PM
2376
Dears,
I have 3 units of ACRD602P with 2 units of AFC.
Could you guide me how to configure the number of AFC?
The units and AFC are connected via A-link
Posted: ‎2021-07-09 04:26 AM . Last Modified: ‎2024-02-14 10:22 PM
thank you very much
it is working
Replies 9
Unexpected Number of Active Flow Controllers
Hello Rami. The Airflow controllers are set up from the front screen of the unit. Path: Main > Configuration > Service > AFC. You will need to call into tech support to get the password for the unit to go under service. Then you will set the number of AFC's connected. If this is already set to two, check the cabling between the units and the AFC's. The unit is not seeing one or both of the AFC, connected.
Number of Active Flow Controllers: Set the number of AFC units in the group (0–5).
Thank you
I can't access the Service screen
could you please help me to have the passwords?
here the Service Codes:
1:
2E9C6E
2:
678308
3:
7173FF
Hello. Here are the three codes. They will only be valid for 48 hours.
BBFEDC
D25E76
611BD0
Thank you
Hello
the service codes changes
what we can do?
Here are the service codes for ACRD602P
Unit 1: 0D6629
Unit 2: 158F4B
Unit 3: 064B02
Hello. The best action is to give you local tech support a call while you are with the units to get the codes off of it. They will change every couple of days. Here are the new codes.
39A97F
47206A
2B07E9
Thank you
thank you very much
it is working
ETCO
Crewman ETCO
Crewman
Posted: ‎2022-09-28 01:06 AM
For the same data center and after around 5 years of working, a few months ago and every couple of weeks we get unexpected number of AFC units alarm, one of the AFC units were down (Off), unpluging the A-link cable and re-inserting it works fine, what may cause this problem? How to solve it?
