Com'X Analog Input for WAGES
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • Com'X Analog Input for WAGES
Romain_Polette
Kirk Romain_Polette Kirk
106
Guillaume_Evrard
Commander Guillaume_Evrard Commander
49
Randi_Dolan
46
Thierry_Baudard
Commander Thierry_Baudard Commander
32
Marvin_Foster
Ensign Marvin_Foster Ensign
Ensign
Posted: ‎2015-11-12 07:27 AM
2
1183
I am trying to understand how the data logging works for the Analog inputs in the Com'X series.
For most WAGES implementations I would expect to get a flow values via an analog signal (Gal/Min, SCF/Min, etc)  The important information needed from that is usage (Gallons, MSCF of gas, etc).  What I don't see is any local integration of the analog signal to create a usage value.  Am I missing something?
Posted: ‎2015-11-16 12:31 AM
1
1048
Overview
Each Analog Input can accept 4 types of sensor :
  • PT100,
  • PT1000,
  • 0-10V and
  • 4-20 mA.
The 2 first types of sensors are temperature sensors, and their conversion rule "Resistor = f (Temperature)" is known,
Thus the device types of those sensors are already available as a built-in device type in the Com'X
For other sensors (0-10V and 4-20mA), the type of measurement cannot be known by advance.
it will be first necessary to create a custom device type (where you will assign the type of measurement, and the conversion rule)
1st simple Example : PT1000 temperature sensor
You just have to connect your sensor and declare them as PT100  or PT1000,
As the PT1000 is a built-in device type, it is already available in the list of sensors (named as Built-in models) :
And you will get directly the value of the temperature in the HMI.
2nd more complex Example : Humidity sensor SHO-100
Step one : define the custom model
This sensor does not belong to the built-in model. It is thus necessary to define it using the "Custom library"
You have to create a  new model,
Give it a name ("SHO-100"),
Define the measurement provided by this sensor as the "Element" field ("Humidity rate") and
Define the conversion rule by specifying the min and max value
NOTE : some measurement are already known (Humidity rate, CO2 Level, Level), if you select one of them, the unit can be selected in a list)
If the measurement of your sensor does not belong to the list, it is possible to create a "Custom" one and enter a "Custom" unit
Using the custom model
Once the model has been created,it will appear in the list of AI choice and it will be possible to use it :
And you will get directly the value of the Humidity Rate in the HMI.
NOTE : If you have done a mistake in the model, you can modify it, and all the instances of this model will be changed
You can also import / export your model to another Com'X
About Modbus-TCP server
The AI are also available through the Modbus-TCP server :
If AI-1 is used, its value (coded as Float32) is available at registers 10000 and 10001 (Most significant register first)
If AI-2 is used, its value (coded as Float32) is available at registers 10002 and 10003 (Most significant register first)
If the device type is a built-in model (PT100 or PT1000), the value returned by the Modbus-TCP server is the temperature value
If the device type is a custom model (0-10V or 4-20mA), the value returned by the Modbus-TCP server is the raw value : voltage or current value
     Regards
1
1049
Overview
  • PT100,
  • PT1000,
  • 0-10V and
  • 4-20 mA.
     Regards
Mauricio_G
Crewman Mauricio_G Crewman
Crewman
Posted: ‎2015-11-16 06:07 AM
Hi Jef,
That's perfect, I'll check the variables on my devices, but it should be straight forward.
Thanks a lot.
Mauricio
