Installation Requirements Pane
Working with asset provisioning
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA desktop client
  • Working in the ITA desktop client
  • Working with asset provisioning
  • Installation Requirements Pane
  • Mark as Read
  • Working with Asset Provisioning
EcoStruxure IT Support
Request Support
Back to Working with asset provisioning
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-06 07:13 AM
Installation Requirements pane
The Installation Requirements pane is used for guided addition/repositioning of equipment to the layout. It is available when Planning>Asset Provisioning is selected in the Application bar.
New / Existing Asset info
Provides information about that component, e.g. how much power the equipment draws, how many power cords the equipment has, how much space the equipment takes up in a rack.
Assign tags
Lists available tags to select and assign to the equipment and rack in the new position in the layout.
Required Redundancy
Selects the level of redundancy for this piece of equipment in the new position in the layout.
Required Network Ports
Selects the amount of fiber or copper connections for this piece of equipment in the new position in the layout.
Add / Move Asset
Adds one or more components to a Selected racks, Each rack in the server room, or Best rack.
When you select Best rack, IT Advisor: Capacity uses information about space, cooling, and power requirements of the equipment being added, to effectively determine the best placement for that equipment (available if you have IT Advisor: Capacity installed).
Show location
Highlights the best location for the selected equipment in the layout.
