Hello, I have the following question: I would like to control my wiser for knx 2 heating panels via a universal actuator. I only have a temperature room sensor. Unfortunately, it doesn't work with Touch 3 because I can only switch it on and off. Someone has already done that thank you in advance Nagl Stefan
Hello Stefan!
Sorry for the late reply!
I like your question because it can be solved with a small script.
Attached you will find the dedicated script and a video which shows how the script works.
I put a lot of comments to make it as clear as possible.
FYI, I added to your request an additional Obj which enables/disables the heating fct in general.
This Obj you can place in the TouchVisu to Switch On/Off this function in general.
Please let me know if it works for you!
Hi Stefan,
to "Practically, it might still be possible to set the target temperature via a temperature object then I could set it using the Touch 3 control"
Yes of course. I kept it like requested as it is a simple update, to motivate to elaborate a bit yourself with the script 😉
Attached you will find the updated script.
Hello Stefan!
Hello, thanks for the help, everything worked great. The main switch is also great. Practically, it might still be possible to set the target temperature via a temperature object then I could set it using the Touch 3 control
Kind regards
Nagl Stefan
Hi Stefan,
