Regarding Multitouch pro MTN6215-5910 RTC temperature control.
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Regarding Multitouch pro MTN6215-5910 RTC temperature control.
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
Hurr
Crewman Hurr
Crewman
Posted: ‎2024-10-10 10:15 PM
600
Hi Everyone!
We are facing some issues with the Multitouch pro MTN6215-5910 RTC. The issues are as follows:-
1) The setpoint command doesn't seem to be working. The ambient temperature goes below the set point (please refer attached pic). (The MTP is configured in cooling mode).
2) There is some glitch in changing from fan mode auto to manual, it needs a long press on - from low speed and sometimes it doesn't work.
The Multi touch pro is configured with the Airzone KNX interface AIDOO-AZAI6KNXxxx.
Attached are the pic of the installed device and ETS file for reviewing the parameters and the group address.
Will appreciate any suggestion on the ETS settings to solve the issue.
Thanks!
MTP test.zip
  • SpaceLogic devices
Hurr
Crewman Hurr
Crewman
Posted: ‎2024-10-27 11:50 PM
Hi Everyone,
Is there a solution to the above. No responses yet. I hope the description of the problem is clear.
