thermostat control from spacelynk
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • thermostat control from spacelynk
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
mostafa_ramadan
Ensign mostafa_ramadan
Ensign
Posted: ‎2024-07-03 06:34 AM . Last Modified: ‎2024-07-14 11:38 PM
1156
I try to control thermostat from application but iam facing issue that i can see actual temp and setpoint in app but can't change it ( any change from app can't go to thermostat but any change in thermostat appear at app )
attached configuration done
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • SpaceLYnk
  • Wiser for KNX
Thomas_Rohde
Sisko
Posted: ‎2024-07-04 11:14 PM
Hello Most,afa_ramadan,
Cristiano is talking about the yellow marked object which is already part of your ETS configuration.
But he refers also to the dedicated group address (marked in green).
This one you should find within the group address selection within your spaceLYnk.
If you still do not find it ... please import the group addresses, or the latest ETS-Project, into your spaceLYnk to have the latest status of your available group addresses.
Kind regards
Thomas
Application Design Engineer
Cristiano_Carli_Ballola
Lt. Commander Cristiano_Carli_Ballola Lt. Commander
Lt. Commander
Posted: ‎2024-07-03 11:02 PM
2
1123
Current setpoint Input and Output cannot share the same group address.
According to you ETS project, current setpoint Input should be the group address linked to the 39 group object
"request setpoint master"
mostafa_ramadan
Ensign
Posted: ‎2024-07-04 10:30 PM
1107
In spacelynk thermostats parameter can't see that request setpoint master
Thomas_Rohde
Sisko
Kind regards
Thomas
