spaceLynk(wiser for KNX)
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • spaceLynk(wiser for KNX)
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
amgedsalem
Crewman amgedsalem
Crewman
Posted: ‎2019-08-29 06:05 AM . Last Modified: ‎2024-07-14 11:49 PM
1320
I have wiser of KNX logic controller  part number: LSS100100 not working
we can not be browsing the webpage to make  the configuration
the device indication only flashing from front side  LED indicator  1  green light
and the IP Connection not working, attached the picture
Please advice us
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • SpaceLYnk
  • spacelynk
David_Navratil
Lt. Commander David_Navratil Lt. Commander
Lt. Commander
Posted: ‎2019-09-05 03:00 AM
1297
For me it clearly looks like controller is not booting.
I will suggest for now to try HW reset (using the button next to the LEDs) – press and hold for 10 seconds – LED 1 start shine red and after 10 sec blinking slowly. Then release and press and hold it again for another 10 seconds – LED 1 again start shine RED and blinking fast after 10 seconds.
If this won’t help, I will also suggest to try reflash microSD card.
follow AN: https://www.schneider-electric.com/en/download/document/AN2_001/
If any of this suggestion won't works, please send device to me for investigation.
Kind regards,
David
Replies 4
Thomas_Rohde
Sisko
Posted: ‎2019-08-29 10:42 PM
1314
can you please share the picture and even more information?
- Is it a new device out of the box?
- Can you reach other devices connected to this IP-Cable?
- Did you built up a small network (PC+W4K) just to exclude other issues?
Kind regards
Thomas
Kind regards
Thomas
Application Design Engineer
amgedsalem
Crewman amgedsalem
Crewman
Posted: ‎2019-08-30 11:36 PM
can you please share the picture and even more information? Attached video Explains the problem.
- Is it a new device out of the box?  Yes, it is
- Can you reach other devices connected to this IP-Cable?  Only the spaceLynk connected to PC to make configuration but
the  connection Ethernet not working to reach the IP address. Attached video explains the problem.
- Did you build up a small network (PC+W4K) just to exclude other issues?  Yes
SpaceLYnk.rar
David_Navratil
Lt. Commander
1298
Kind regards,
David
Thomas_Rohde
Sisko
Posted: ‎2019-09-19 10:46 PM
Hello Mezied1993-Huss,
any news on that topic?
Kind regards
Thomas
Kind regards
Thomas
