Share Your Feedback โ€“ Help Us Improve Search on Community!
posh button pro to be discontinued
SpaceLogic KNX Forum
Showing results forย
Did you mean:ย
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • posh button pro to be discontinued
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dรถlger
Commander Heribert_Dรถlger Commander
31
SpaceLogic KNX - 4สบ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
IC_Systems
Captain IC_Systems
Captain
Posted: โ€Ž2021-11-02 04:13 AM . Last Modified: โ€Ž2024-07-14 11:45 PM
696
from a while, I see that the push button pro will be discontinued and this makes customers complain!
it's not been a long time since the PB pro was produced! do you aim to replace it with the PB Pro+T?
regards,
Best Regards,
  • Thumbnail of SpaceLogic KNX - 4สบ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Documents
Thomas_Rohde
Sisko
Posted: โ€Ž2021-11-11 11:36 PM
1
685
Hello IC-systems,
sorry for the late reply!
Yes you are of course right ๐Ÿ™‚
We do not phase out such a young product without having an update in hand ๐Ÿ˜‰
When I take the example of System M (MEG6180-0325) then you simply use this article number MEG6185-0325 and you get the same pushbutton which has on top a temperature sensor included which fits perfectly in combination with our SpaceLogic KNX Valve Drive Controller (MTN6730-0002) or SpaceLogic KNX Fan Coil 0-10V Controller (MTN6730-0003) as they have the room temperature calculation directy included.
Kind regards
Thomas
Application Design Engineer
IC_Systems
Captain IC_Systems
Captain
Posted: โ€Ž2021-11-07 11:18 PM
690
Does anyone here have an answer, because we use this product in many bids and we don't have the required quantity of PB-Pro in our stock.
best regards
Best Regards,
Thomas_Rohde
Sisko
1
686
Hello IC-systems,
Kind regards
Thomas
Erwin-vd-Zwart
Janeway
Posted: โ€Ž2021-11-11 11:57 PM
๐Ÿค” I understand the confusion.. why didnโ€™t we just updated the product under the same reference number? I understand that you need a new reference number for each product but if the original is faced out anyway then you donโ€™t need a new reference in my honest opinion. Hence such questions now ๐Ÿ˜‰
ย
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2025 Schneider Electric
