homeLYnk firmware v1.5.0
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • homeLYnk firmware v1.5.0
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
sesa288847
sesa288847 Schneider Alumni (Retired)
Posted: ‎2016-04-20 06:11 AM . Last Modified: ‎2024-07-14 11:56 PM
1205
New firmware for homeLYnk has been released! All news and updates can be seen in attached documents.
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
homeLYnk FW v1.5.0.zip
Tags (6)
  • 1.5.0
  • firmware
  • home automation
  • homelynk
  • knx
  • modbus
Replies 5
DK-Michael
Commander DK-Michael Commander
Commander
Posted: ‎2016-04-25 05:29 AM
Hi JAKUB HRADEK
Thanks for the update. I have just installed it and now I'm a bit startled that my "Counter" trends are empty. Also, I was very much looking forward to the option of higher resolution on the trends, but to get this on my existing trends, I will need to delete my trends and make new ones? What about the historical data? The option on the existing trends are grayed out.
Is there a workaround for these issues?
Best regards, Michael
________________________________
Michael Johansen
Solution Architect
M +4528991535
E michael.johansen@se.com
LinkedIn https://www.linkedin.com/in/mich4el/
sesa293024_brid
Ensign sesa293024_brid Ensign
Ensign
Posted: ‎2016-04-25 05:57 AM
Hi Michael,
Counter needs some time to re-calculate (up-to 30 mins). After this period of time it should be visible. There is no possibility to change resolution of already created trends. As fine data are re-calculated and deleted after proceeding. The only way to keep the old trends data is to leave old trends and create the new ones with higher resolution. If your problem with counter persist please send ma a backup of your project for faster communication.
Have a splendid day,
Vlastimil
DK-Michael
Commander
Posted: ‎2016-04-25 06:05 AM
Hi Vlastimil
Thanks for your quick reply Ok, fair enough with the counter values. I'll let you know if it does not show up.
Too bad with the resolution but thanks for the proposed solution. Btw, there is a small bug (I assume) when clicking on existing trends where the number of digits are grayed out, it is still possible to change the values by clicking the small arrows next to the number.
Thanks, and you too 😉
Michael Johansen
Solution Architect
M +4528991535
PetrMares
Commander PetrMares Commander
Commander
Posted: ‎2016-04-25 06:14 AM
It is possible to change decimal numbers via clicking arrows up/down. Nevertheless this new value cannot be saved. I'll put it in the list.
DK-Michael
Commander
Posted: ‎2016-04-26 06:27 AM
Hi Petr
Yea, I know, that's why I wrote "minor" bug 😉
VLASTIMIL BRAZDIL, My homLYnk has now finished calculating. I did not take ½ an hour. It took from 14:00 -> 02:00. In that period it has not logged any data. My counter values are still gone and there are just one large peak left from 02:00 with the actual counter value. I have attached two screenshots and a backup:
https://schneider-electric.box.com/s/5i011rj96cw135hakskd5kh8wqtuhmkg
It is a device I'm using as a demo to show customers, so the data is not critical in any way. It's only to help you and to be able to guide my customers if they want to upgrade.
Michael Johansen
Solution Architect
M +4528991535
