ESF file with cirylic symbols import into homeLYnk
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • ESF file with cirylic symbols import into homeLYnk
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4Ęş Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
Alexander_Efremov
Alexander_Efremov Schneider Alumni (Retired)
Posted: ‎2015-11-24 02:21 AM . Last Modified: ‎2024-07-14 11:56 PM
6
1357
When you import an esf file with the names of objects in Russian, we get the squares in place of object names in the HL (see attached file).
Is there a way to solve this problem without renaming all the objects manually?
Kind regards,
Aleksandr,
  • Thumbnail of SpaceLogic KNX - 4Ęş Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
PetrMares
Commander PetrMares Commander
Commander
Posted: ‎2015-12-09 05:32 AM
keep in mind firstly set correct character settings to Cyrilic -> Windows-1251
after that you can make Encoding >> Convert to UTF-8
Replies 6
sesa299442
sesa299442 Schneider Alumni (Retired)
Posted: ‎2015-11-25 07:04 AM
1272
can you attach example of the esf file?
BR
Tomas
Alexander_Efremov
Posted: ‎2015-11-25 07:29 AM
1272
Hi, Tomas.
ESF file in attache.
BR,
Aleksandr
Meridiannaya 2-60.esf.zip
sesa299442
Posted: ‎2015-12-09 02:02 AM
1272
Hello Alexander,
here I attach a file, which you can restore and it works fine.
The problem of your file is encoding ( it is encoded in type 1251).
You can open the file in Notepad++ and select Encoding >> Convert to UTF-8.
Then save the file and you can use it in homeLYnk.
I do not know, when is the original encoding of the esf file coming from,  but is most probably derived from language settings of your Windows PC or ETS.
Best Regards
Tomas
Meridiannaya 2-60_UTF8.esf.zip
PetrMares
Commander
sesa299442
Posted: ‎2016-04-25 05:25 AM
1272
Hello Alex,
can you mark this topic as Answered? 🙂
Tomas
Alexander_Efremov
Posted: ‎2016-04-25 05:38 AM
Thanks, Peter.
It's work fine!
Best regards,
