econfigure - Ets group adress generated (export)
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • econfigure - Ets group adress generated (export)
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
domotiqa
Lt. Commander domotiqa
Lt. Commander
Posted: ‎2021-06-16 12:40 AM . Last Modified: ‎2024-07-14 11:46 PM
580
Another boring problem on econfigure.
Another issue/point would be to create common function everytime we create a light, shutter, temperature.
For example, when creating dimming light, only ON/OFF and status are used, and if we link buton dimmer, maybe 4bit. But the dimming absolute 1 byte are not created...
idem for shutter.
So if we need these address on touchscreen, or supervision, we have to create virtual buton...and address are not in order...
For light, it should be great to automatic create ON/OFF, status; relativ and absolute and status...
For shutter also UP/DOWN, status absolute and binary.
Thermostat also
Detector also (auto/manu, reset...)
If we created 2light and a buton, then link them. then create a new buton and link only one light... the address became strange. Why not creating first address of each light, then the group...
Would be very appreciated.
Smarthome & Smartbuilding Expert
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • eConfigure
FZetina
Commander FZetina Commander
Commander
Posted: ‎2021-06-16 03:34 AM
Hi
As discussed by email, thank you for the feedback. Every comment and suggestion for improvement is welcome. We'll discuss it with the development team to understand the possibilities.
Fernando Zetina
FZetina
Commander
Hi
Fernando Zetina
